Ir para o conteúdo principal
iPod Classic 6th Generation. Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
903 Perguntas Visualizar todos
Will restore erase all of my music?
If you restore your ipod will it erase all of your music on the ipod? and if so, do you have to restore it? thanks heaaaaaps tho!!!
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
4 respostas
Solução escolhida
Yes it will. If you have to do a restore, depends what's wrong with your iPod. The trick would be to either have it backed up before ;) or get a USB to ZIF adapter, remove your hard drive and copy your files with some of the freeware that is out there (depends on your OS) to your computer. Then restore your iPod and reload the music. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 3
If you want to get back your erase all of your music. Well Lots of iPod music recovery software are available in the market. But reason is that how to recovers and restore my erase or deleted Files. I used one the best iPod music recovery this software very user friendly and no need technical experience. It can easy to use the software. Kernel Recovery for iPod software recovers all erase or corrupt music very small minutes.
Pontuação 0
Really Kernel for iPod Data Recovery Tool is more advance or effective software. It can quickly & easily recover all lost, corrupted, accidentally deleted audio and videos song. The free demo version also available. click here :
Pontuação 0
Yes it will. If you restore your ipod, it will erase all of your music on the ipod. But you don't need to worry about that. Only if you sync the music files to iTunes, the problem that how to recover music from iPod seems simple after you restore your iPod. You can use Data Recovery software to help you restore music files. It can recover all the music files in a few minutes.
Pontuação 0
Adicionar a sua resposta
Renee será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 18
Duração total: 16,291
