Ir para o conteúdo principal
The model UA40F5500AM is a 40-inch smart television produced by Samsung.
Why is my tv not having a stable screen booting
I have "32" ELIFE smart tv. When you on it, It boot to a certain point and then the screen goes off. It keeps repeating like that. Though there's stable power supply. Kindly help me resolve this issue please
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
@francisdarkoh you are saying the screen turns off. This could actually be your backlight. Darken the room, turn your TV on and once the screen is dark, use a flashlight and shine that at an angle against the screen. If you can now make out your picture, you know it is your backlight strips that have failed. Those can most likely be replaced.
If you can not, its time to unplug your tv, remove the back cover and to take a look at the boards. Check for any damaged (burned or otherwise damaged) components. Post some pictures of your boards with your question. Adicionar imagens a uma pergunta já existente
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Francis Darkoh será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Ao todo: 138
