Ir para o conteúdo principal
Pergunta encerrada
My screen is showing vertical lines
My screen is showing vertical lines at startup
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Connect to an external monitor to determine if you are having problems with the graphic chip set.
Esta resposta foi útil?
Pontuação 0
I did that and the external image is fine. Any thoughts? Also, tried
another known good screen......
Rob
Pontuação 0
It sounds like your LCD is damaged, assuming that the lines don't disappear after startup. Here's a guide to replace an LCD
iBook G4 12" 1.33 GHz Display Replacement
Pontuação 0
1 comentário:
The LCD may or may not be the problem. The video data cable could be bad or the cable ends not seated properly. Don't you think they ought to look there first since the LCD can only display the information given to it. If the cable is bad the LCD won't display a proper picture.
por
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 2,497
