Ir para o conteúdo principal
Repair and disassembly information for Logitech's MX Keys wireless keyboard. Identifiable by model number YR0073.
I need to change the USB C port.
Can you tell me what is the replacement part number for the USB C port on the keyboard? The black color portion inside the port is broken and I will need to replace the either 14P USB C receptacle. Is there a part number for this that you can provide?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hi,
Here’s a YouTube video showing removing of mainboard:
https://m.youtube.com/watch?v=gzVEoeGeZw...
The USBC port is a standard connection which you should be able to purchase at electronics parts store or online.
You will need to have tools/skills to de-solder and remove the broken one then solder in the new one.
If you’re not comfortable with doing this then you may need to consider taking it to a repair shop.
Hope this helps
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Srihari Jayaram será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 13
Ao todo: 274
