Ir para o conteúdo principal
device only charges to 1/2%, when not charging it dies in 3 seconds
my iphone 6 plus used to work smoothly, but after my mom brought it to work, the phone somehow only takes in 1 - 2% charge, not increasing, AND the touch id somehow "magically" disabled itself.
I replaced the battery like six months ago with an ifixit battery kit (YOU SHOULD BUY A KIT) for around 25$ and it worked fine before my mom bought it with her.
Esta é uma boa pergunta?
Pontuação 0
2 comentários
The battery is probably faulty, and it started acting up at work because of coincidence. Buy a new one or contact iFixit.
por
i allready did, they gave me a new one since mine still has warranty, no work .So i flashed my device and it worked, still no touch id
por
Adicionar um comentário
1 resposta
Solução escolhida
Hi, there’s 3 potential areas of fault with Touch ID on your 6s Plus.
If the home button isn’t functioning any longer then you lose access to Touch ID.
If you haven’t seated the flex for the button correctly/fully then you won’t have Touch ID.
If you have damaged the flex cable you won’t have Touch ID.
Touch ID can be restored, but only by Apple or certified repairer with the equipment to read the encoding off the phone and write the information to a new button flex.
But you probably won’t like the cost.
You can replace the button and get home button function yourself, but you still won’t have Touch ID.
Esta resposta foi útil?
Pontuação 1
2 comentários:
the home button has no physical damage after inspection, and the rubber gasket was never replaced before
Can you send me the link to the equipment to read the encoding off the phone and write the information to a new button flex?
por
Sorry, like I said you won’t get the tool, you have to take it to Apple or an Apple certified repair shop to replace and restore Touch ID.
por
Adicionar a sua resposta
Tran Anh Khoa (Kyle) será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 11
Ao todo: 54
