Ir para o conteúdo principal
Subaru WRX. Non-STI model Standalone model from the Impreza.
Traction control light on-hill assist light on(off)
What I need to check or buy to repair it?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
Here is an article from “myrandomtechblog” that explains one fix for the issue.
https://myrandomtechblog.com/automotive/...
It seems to cover what you are describing in the title and looks to be a relatively easy fix.
Apparently there was a Subaru recall back in 2019, but it’s probably a part that will continue to need replacing every so often unless an aftermarket supplier makes an upgraded version of the switch.
Hope this helps
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Michael Williams será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 30
Ao todo: 355
