Ir para o conteúdo principal
The March 2015 update of Apple's 13" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
Hi there, Is it possible to upgrade a early 2015 13inch MacBook Air ra
Hi there, Is it possible to upgrade a early 2015 13inch MacBook Air with retina display to 2TB NVMe SSD
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Yes, the Blade SSD can be swapped out, here's the guide MacBook Air 13" Early 2015 SSD Replacement as to what to use your system offers a custom Apple PCIe 3.0 x4 interface. You can use a pin compatible drive from OWC or Transcend or use an adapter to convert the custom interface to a M.2 interface to plug in an M.2 drive. Depending on your use you may encounter issues with some of the M.2 drives so be careful on who’s you use and of course backup often.
Esta resposta foi útil?
Pontuação 0
I recommend to use a Sintech Adapter & a Samsung 970 EVO Plus SSD (With Firmware 2B2QEXM7 or 4B2QEXM7 and you shouldn't have any issues. I have been running this setup for over a year and so far it has performed perfectly.
Pontuação 0
Adicionar a sua resposta
Abdallah Seif será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Ao todo: 38
