Which diode do I need for my tv?
Hi there,
After finding this post I took apart my 40PFL9705H Philips TV, with the same issue as described in the post. I was able to find a faulty diode, but I am unsure where to order a replacement and with what specifications.
I have marked the faulty diode with an X (middle bottom):
It's labeled as D203:
The sticker on the board:
I hope someone can help me, thanks!
Esta é uma boa pergunta?
5 comentários
Does it say anything on the diode ?
por Daniel
Also have you tested it off the board diodes can give different readings in circuit .
por Daniel
I have removed the diode and got a different reading this time, so the issue does not seem to be the diode. Any ideas how to troubleshoot further?
por Jason
Sorry, I’m truly no expert. I’d just replace the board tbh. Hopefully someone decent at T.V repair steps in. You could look up the service manual for your model. It goes through everything in there in detail about fault finding. Also look up videos on T.V fault finding. If nobody does step in. Sorry not much help but good luck in your endeavour. I’m sure you’ll get there .
por Daniel
Thanks for the help, i feel way out of my depth here so I will see if I can find a replacement board.
por Jason
