The phone is charging very slow
phone is charging very slow. almost take 30 min to charge 10%
Esta é uma boa pergunta?
Hi, there could be a few reasons to cause slow charging. Obviously if your using it while charging it will slow it down that’s one. If the battery is getting old that can also cause it. The main one is the charging outlet or plug. The more AMP the faster the charge. For instance a 5v 2.1 A will charge slower than 5v 3.1 A . Now if your using the same plug and everything as you always have it’s probably the battery. Or finally it could be something running in the background on your device a background process. Try using a different USB plug or charging the phone while it’s completely turned off see if that helps.
Esta resposta foi útil?
Well I will suggest you to update your phone to it's latest software version and if the battery is is too old then will suggest you to go for the battery replacement and if you have budget at the moment then you can go for a new phone.
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 21
Ao todo: 203
No , it is not like that
por Topper 9th B
