It keeps glitching. It keeps turning black
It keeps glitching. It keeps turning black every single time and I can just hear him and then what do I do because I really don’t know what to do. Can somebody help me
Esta é uma boa pergunta?
@ashleynand72110 sounds like a backlight issue. Turn the TV to a channel where you can hear the sound. Next, use a flashlight and shine the beam at an angle against the screen. Do that in a darkened room. See if you can make out shadows or shapes. If you do, then it is your backlight that has failed. If you do not see anything, unplug your set and remove the back cover. Then visually check the boards for any obvious damaged components. Check all the wiring and unplug the wires and plug them back in, make sure they are properly seated. Post some images of all of your boards with your question. Use this guide Adicionar imagens a uma pergunta já existente for that, so we can see what you see. It is possible that this is either a power board, or a T-con board issue.
Ultimately, knowing that this is a Philips, I am for certain that you need to replace the LED backlight strips.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 15
@ashleynand72110 what is the exact model number for your TV?
por oldturkey03
