Ir para o conteúdo principal
Morris Garages is a British automotive brand registered by the now-defunct MG Car Company Limited, a British sports car manufacturer.
EPB system fault after replacing rear brake pads.
After changing rear brake pads on my MG ZS EV 2020 car has come up saying EPB system fault. What should i do as the car wont come out of service mode with the scanner and the hand brake doesnt work also tried to re calibrate the brake pads but the car wont allow that due to being in the service mode, spoke to the MG dealer there charging huge amount of money just to dignose the car.
Any guidence would be helpfull.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
I have the same issue..have you resolved it?
Esta resposta foi útil?
Pontuação 1
2 comentários:
With the MG’s everytime you do any sort of brake work the EPB busts, so basically its the EPB Moduel you gotta get replaced and the only peopel who can do the is the mains MG dealer
por
Why does the EPB bust????????????????
SInce it is electrical, maybe you must disconnect the battery when doing brake work.
Or maybe there is a recalibration proceedure.
por
Electrical Parking Brake, EPB for short.
Parking brakes are the rear brakes. Electrical means they are electrically activated.
Therefore, you must have missed something in your reassembly, like an electrical connector.
Or it is possible you damaged something associated with the parking brake operation.
Recheck the job.
Pontuação 0
Adicionar a sua resposta
nomi será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 28
Ao todo: 2,033
