Says water full when tank is empty
We have made sure the tank is empty, but the water full light will not go off and the unit will not turn on.
Esta é uma boa pergunta?
Pontuação
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 31
Ao todo: 174
@resafuller it is possible that you have a stuck float switch. Remove the tank and take a look at the float. That is the part that sits in the tank and as the water tank fills, it moves up, eventually it will trip a switch that turns the dehumidifier off. If it is stuck, or if the switch has failed, your dehumidifier will not turn on,. Post some good pictures of that your float etc looks like so we can see what you see. Then we can hopefully work on a proper fix for this. Adicionar imagens a uma pergunta já existente
por oldturkey03
@resafuller thank you. Whoa, that is a bit odd looking :-) I expect ,more of a float. Can you take a picture of the schematic that is glued to the bottom.? Let's see if that give us more of an idea
por oldturkey03
