Ir para o conteúdo principal
O GameSir X2 Type-C é um controle de jogos móvel para dispositivos Android com porta de carregamento USB-C.
How can I buy the USB Port?
My USB Port was broke! How can i buy the GameSir X2 Type-C replacement USB-C Port?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
There are plenty on Aliexpress.com You just have to search for one that is physically the same.
Esta resposta foi útil?
Pontuação 0
5 comentários:
Would you mind telling me what keyword you have used to search on AliExpress for the USB port? As I tried but can't find any. Many thanks.
por Compartilhar
@leighm87778
You can also see if you can find the correct one here
por Compartilhar
Any luck? I couldn’t find this type-c replacement part anywhere, searching in Aliexpress for almost an year, couldnt find even in Mouser page.. could someone please help with actual product page, I have two gamesir controllers sleeping without this part.. Your help is much appreciated
por Compartilhar
I think you are out of luck for a repair as that connection is Unique Patent — 51° Adjustable Type-C Plug. That would mean you can't buy one.
por Compartilhar
Can you take it apart and post some photos?
por Compartilhar
You can't buy it anywhere, I personally was able to fix mine, I checked the pinout, shortened the cable by half, and soldered the wires directly to the connector
Pontuação 0
1 comentário:
can you post where and what you bought for this fix?
Maybe some pictures?
por Compartilhar
Adicionar a sua resposta
Salvo Alba será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 47
Ao todo: 746
