Poor carbonation from my Sodastream Spirit
I do all the things suggested to get good carbonation but nothing makes any difference and I get no fizz in my water please help my older model 40 years is still perfect.
Esta é uma boa pergunta?
Check the CO2 Tank: Make sure it’s properly connected and has enough gas. Sometimes, even if a tank feels full, it might not be delivering enough pressure.
Examine the Carbonator: Look for any leaks or cracks in the unit itself. A leak could prevent proper carbonation.
Clean the Nozzle and Tubing: Over time, sediment or mineral buildup can affect performance. Clean the nozzle and any tubing that connects the CO2 tank to the bottle
Check the Pressure Regulator: If your carbonator has a pressure regulator, it might be malfunctioning. You might need to get it repaired or replaced.
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 18
Últimos 30 dias: 57
Ao todo: 1,133
