The engine is shaking while in idle state , Jerks and stops.
engine not stable, jerks even in idle state
Esta é uma boa pergunta?
Pontuação 0
3 comentários:
@okeyemmanuel what exact year, model and engine size is this. It sounds like an issue with the idle but there could be many reasons for this. Something as simple as a failed sensor to as complex as a timing issue. The very first thing you want to do, is to scan the OBDII and let us know what codes, if any your Corolla shows you.
por
Could be a multitude of things as @oldturkey03 mentioned. More information would help as well, if you're able to get it to an autozone or have a reader (OBD) scanner you can have the codes pulled from the computer to see what errors it's throwing, this is a cheap/free method to narrow down the issue.
por
could be multiple reasons:
- If you press on gas pedal, and it still shakes, then it maybe the engine plugs and/or coils.
- Engine base, where the engine sets, this would happen when you put on D or R.
por
Adicionar um comentário
