Ir para o conteúdo principal
The Big Joe J1 is a product for which this page offers detailed repair and usage information. Learn more about its purpose, capabilities, and physical characteristics.
Sepeda motor honda mio j
Kenapa motor tidak bisa starter tangan Pdahal aki motor baru?
Translation Indonesian - English
Honda mio j motorbike
Why can't the motorbike start by hand even though the motorbike battery is new?
Esta é uma boa pergunta?
Pontuação 1
5 comentários:
@nongfanri can you verify that your motorbike is a LIttle Joey J1 Series (2019) If not, let us know the exact model. Also, tell us everything you have checked and everything you have tried. What is it exactly that your motorbike does? What exact symptoms doe it show/give you?
Translation
@nongfanri dapatkah Anda memverifikasi bahwa sepeda motor Anda adalah LIttle Joey J1 Series (2019) Jika tidak, beri tahu kami model pastinya. Juga, beri tahu kami semua yang telah Anda periksa dan semua yang telah Anda coba. Apa sebenarnya yang dilakukan sepeda motor Anda? Gejala sebenarnya apa yang ditunjukkan/diberikan kepada Anda?
por
Cara bongkar filter udara
por
Bongkar blok mioj
por
@adityawarman can you verify that your motorbike is a LIttle Joey J1 Series (2019) If not, let us know the exact model. Also, tell us everything you have checked and everything you have tried. What is it exactly that your motorbike does? What exact symptoms doe it show/give you?
Translation
por
i am facing these problems also
por
Adicionar um comentário
3 respostas
Cek dinamo, socket kabel, relay.
Semoga bisa terbantukan
Esta resposta foi útil?
Pontuação 0
Karena kabel koilnya putus atau businya sudah tidak bagus
Pontuação 0
проверь клемму от аккумулятора , и стартер
Pontuação 0
Adicionar a sua resposta
Nong Fanri será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 18
Últimos 30 dias: 132
Ao todo: 3,526
