Replaced HD but now won't power up
I replaced HD using repair directions but now I don't get anything when I press the power button. Checked to see if keyboard connector was loose which it was, reseated, reassembled still nothing. Yes the battery and charger are plugged in.
Any suggestions?
Esta é uma boa pergunta?
5 comentários
It does nothing? No tone, no noises, no lights?
por mayer
The model is PBG4 15.2/1.67Ghz-128/1GB (2x512MB).
The AC Charger is working with a green light at the plug.
I replaced the hard drive after it crashed while my daughter was making an imovie. The Genius bar could see the HD and it failed the verify and repair. I removed the drive and put it into a USB external case and continue to hack at that but that is a separate issue for now.
I got a new 250GB drive thru Ifixit and followed the directions.
por brianwen
I have checked the power switch for operation using an ohmmeter and it looks good.
I have carefully inspected the top case cable and connector with a 7x magnifying loop and can not see any damage.
I have tried resetting the Power manager unit to no avail.
I pulled the new HD back out and inspected the connector an how it is seated on the logic board.
I am down to a PRAM battery, it was never changed. Would that battery go dead if the the PowerBook was apart for a week?
The PowerBook took a hard fall about a year ago and is dented in the corner where the charger plugs in but it has worked fine all that time. So it could be the DC in board. Ifixit doesn't have a board for it.
Is it likely that I static damage the logic board? I was careful but didn't use a static mat or wrist ground.
I haven't put the old drive back in to see if the new drive I got is bad but that seems that I would at least get a noise from the PowerBook when I tried to power it up .
Thanks for all the help so far.
por brianwen
Brian, your pram battery was never changed so it's normal it could be dead after all your PB is a five years old computer. Use your ohmmeter to verify the pram battery charge. Should be a DC measure but I don't know the voltage a good battery should read. I think it's 3.6 volts but someone could correct me if I'm wrong.
por lemerise
Looks like the problem is with the connector on the top case cable where it connects to the logic board. I was able to get it started by pressing on the connector while pressing on start button (hoods up start). I will check it out under a microscope at work tomorrow. Probably have to replace the cable.
por brianwen
