Pular para o conteúdo principal
Complete disassembly and installation guides for most iPods, including iPod original, mini, shuffle, nano,classic and touch.
7412 Perguntas Visualizar todos
Lost my password on iPod
hi mate i forgot my Ipod password and it would have been impossble to have used the Ipod could you some thing about.
chez thanks
Respondido! View the answer Também tenho esse problema
Esta é uma boa pergunta?
Pontuação 0
Comentários:
Please, provide us with the last four numbers and letters of the iPod serial number (you may find them printed on the unit), and/or the exact model of the device.
por
Which iPod is it? What have you tried? When do you get the error message?
por
Adicionar um comentário
3 Soluções
Solução escolhida
Plug it into the computer it was set up on and reset it.
Esta resposta foi útil?
Pontuação 2
Since you never mentioned the iPod you have, I can't give specifics. I am assuming it's an older device and making the assumption it is an iPod Touch. This guide covers how to do a recovery mode restore to get the iPod working again. The procedure is interchangeable .
For clickwheel devices, refer to these instructions:
  • Plug the iPod into a computer.
  • Press and hold menu and the center button.
  • Wait for the screen to turn off.
  • When it gets to the Apple logo, hold the center and play/pause buttons in. This will put the iPod in Disk Mode, where it can be resored.
Please note both methods will erase all of your data.
Pontuação 2
this might be able to help you
If you enter the wrong passcode six times in a row on your iphone, ipad , or ipod touch you’ll be locked out and you’ll see this message:
iPhone is disabled
iPad is disabled
iPod touch is disabled
Recovery method is the sure fire , quickest way to get back access to your ipad, but if you don’t have a back up file of your ipad then you will be going back to factory reset mode with recovery mode
i found this inforamtion online ..it might help .. More here
Pontuação 0
Adicionar a sua resposta
akhayre2000 será eternamente grato(a).
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Todo: 436
