Ir para o conteúdo principal
Repair documentation for the Sony PlayStation 5 DualSense controller. Model number: CFI-ZCT1W FCC ID: AK8CFIZCT1
84 Perguntas Visualizar todos
Why is my R2 become less sensitive? Its very easy to press
My R2 is very loose. It's not the way it was before. And it's barely used
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
This all boils down to how the controller works, when you press the trigger you are pressing a spring which in turn pressed a button, this is how you get trigger resistance and and all the other things you get with a controller. But if you use it too much you could wear down the spring in the controller. To fix all you have to do is replace the spring which you can find here
Imagem de PlayStation DualSense Controller Trigger Button Cover Set
Produto
$9.99
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Laving será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 14
