Ir para o conteúdo principal
Repair guides for the MacBook.
3786 Perguntas Visualizar todos
Keyboard issues with a single key: solution?
I know this question is old by I have exact the same question. I am in the edge of ordering a top case but what if it is not the keyboard? and is something else? is it for sure a keyboard problem?
Esta é uma boa pergunta?
Pontuação 0
2 comentários
Death and Taxes are for sure.
por
What else could it possibly be? (same Question doesn't give a lot to go on).
por
Adicionar um comentário
2 respostas
Pergunta mais útil
I reckon your question comes from the one in which a user reported a malfunctioning single key, the "shift" key.
Well, if your malfunction is limited to a single key, you may try to press it. Does it "click" like the others? Or does it look and "sound" stuck?
If its the latter, you may pry very carefully the single key, check if it "clicks" or physically connects. I never pried off the keys out of my Macbook, and I don't even know for sure if this guide here is for a Macbook or a mislabeled Macbook Pro (whose keys I know they can pried out) http://www.ehow.co.uk/how_7147760_reatta... , however, if it was "stuck" you may try to gently reseat and clean it.
Failing that, if the keyboard is mechanically sound, a replacement would seem much more likely...
Esta resposta foi útil?
Pontuação 2
I have a similar issue, my "b" key does not click anymore and does not register every time it is pushed.
I have to make a conscious effort and hit the key a few times in order to get it to work.
Pontuação 0
Adicionar a sua resposta
stfan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 749
