Ir para o conteúdo principal
Model A1237 or A1304 / 1.6, 1.8, 1.86, or 2.13 GHz Core 2 Duo processor
Why is my laptop not charging when I plug it in?
My laptop is not charging when I plug it in. I've tried plugging in and out the charging port, and I tested the charger with another laptop. There's no visible damage on the charging port either, it seems perfectly fine. The light isn't lighting up on the charger, even though it does on the other one. What could be wrong?
Update (05/04/24)
It ran out of battery ages ago. Also, the display wire, hinges and clutch cover are broken.
Esta é uma boa pergunta?
Pontuação 0
14 comentários:
@hamzas Is it fair to assume it is not starting up when connect to a Magsafe power adapter?
por
@oldturkey03 yes, it doesn't start up when connected to a magsafe power connector
por
@hamzas So three is absolutely no light (no Amber or no Green light). No sign of life when you plug it in etc.? The MBA appears to be totally "dead"?
por
@hamzas let's see if a different Magsafe will work for you :-) keeping our fingers crossed but still having some major doubts. There just seem to be a lot going on with your MBA
por
Exibir mais 9 comentários
Adicionar um comentário
1 resposta
When you plug in the MagSafe charger does the connector LED lighting up, if it is what color is it Amber or Green?
Esta resposta foi útil?
Pontuação 0
7 comentários:
No light at all
por
@hamzas - Do you have access to a second charger? As it’s either dead or the MagSafe Port’s dirty or bad being the most likely issue.
por
Yes. none of them are working with the mba. I know they work because I have a 2012 unibody mbp i tested them on.
por
Thanks for the help. I'll try it and see if it works
por
Exibir mais 2 comentários
Adicionar a sua resposta
Hamza Safdari será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 24
Ao todo: 310
