Ice Maker Doesn't Stop When Bin is Full
I've had the ice buildup issue in the past and had the whole thing replaced (including the PCB). Since then no more buildup, but at some point after the repair, the ice maker stopped stopping when the bin is full. It will just run until there is basically a block of ice from the tray to the bin. I've never left it running to see how bad it will get, but I'm basically forced to run it for a short period and then turn it off or I will have to start breaking out ice to clear a path for it to drop. I've recently replaced the auger motor which has the sensor eye on it (at least that is what I assume it is for), but that didn't help either. I haven't replaced the bin yet, but now sure how that could make a difference. One thing I did notice when looking at the PCB, there is a 4 wire plug at the top that isn't connected to anything. I never looked at this prior to the replacement, so I'm not sure if this is by design.
Esta é uma boa pergunta?
