Ir para o conteúdo principal
iPod Classic 6th Generation. Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
903 Perguntas Visualizar todos
iPod won't turn on or off?
My iPod's screen is frozen. It won't turn on/off or anything what could be the problem/solution?
Esta é uma boa pergunta?
Pontuação -1
1 comentário
Is the little switch on the top in the "Lock" possition?
por
Adicionar um comentário
2 respostas
Pergunta mais útil
Press and hold the middle button and the menu button at the same time. This should perform a hard reset and unfreeze the device.
Esta resposta foi útil?
Pontuação 1
My iPod has had similar issues in the past, in which even a hard reset would not work. If that is your case, just let it drain itself dead and then charge it back up. You should be good to go then!
Pontuação 0
Adicionar a sua resposta
Sabrina será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 2,239
