How to disable the front camera?
Hi,
I managed to save the iPhone 4 of my friend who remained under a tap running for over an hour. The motherboard works, it's incredible that is, elements that do not work are:
- LCD (dead) (repairable)
- Proximity sensor (repairable)
- Front camera (irreparable)
The front camera is most affected by water damage. The connector of the front camera of the motherboard died.
I tested with another front camera, but to no avail. The camera still does not work.
In addition, when we switch camera (from the back to the front) there is no possibility to return back to the rear camera. The shutter is closed and the switch button is not visible. What prevents them from using the back camera. If he wants to use the back camera, he is obliged to restore the phone so the rear camera is opened at the opening of camera.app on first use.
So I wonder if there was a way to disable the switch of the camera front, with the jailbreak or an application or a restriction.
Thank you in advance for your help.
carlitostyle
Esta é uma boa pergunta?
