Can't insert replacement keyboard cable
I damaged the keyboard cable while replacing the battery. I've got a new cable and have removed the logic board but the cable doesn't seem to want to fit or slide into the slot. The ribbon cable is very thin and just crumples up when trying to insert it. Is there a trick to making the connection? It almost appears that the table should slide all the way through the slot but I can't seem to get more than about 1/8 inch of the tab into the slot so there is no contact.
Esta é uma boa pergunta?
