Ir para o conteúdo principal
How replace home button can't push-button?
My home button stop working the problem is that i cant push him.
His flexibility disappear and i can't push him.
what the part's i need i see that 2 parts sexist one is external rubber part and a small dual cable.
What part i need and where the cable location?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
Be sure you want to undertake this adventure before you start.
tools you will need.
heat gun, utility knife, very small philips head screwdriver
the flex cable is more than likely the problem if the flexibility is gone. you can buy them online for about 5$ but if your going to go to the trouble you should just replace everything, flex cable and button. total cost 15$ because you need to get new tape/glue strips to hold the screen down.
there is a repair guide on here for you to follow
iPod Touch 4th Generation Home Button Ribbon Cable Replacement
the cable is underneath the mid plate
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Evgeny será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 13
Ao todo: 5,358
