Ir para o conteúdo principal
A segunda geração do iPad com modelos Wi-Fi, GSM e CDMA. Alguns modelos foram atualizados antes do iPad 3. O reparo é difícil e requer procedimentos de calor e separação.
729 Perguntas Visualizar todos
Pergunta encerrada
Increasing iPad 2 Battery life
Now that the iPad 3 has been released, with it's huge battery, will an iPad 3 battery fit in an iPad 2?
It would be great if it did, battery life would jump to over 20 hrs!!
Thanks,
DG
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Thanks for the reply.
The battery packs looked similar in the pictures, and changeing the connectors would not be impossible.
Anyway, it was just a thought.
DG.
por
Adicionar um comentário
1 resposta
Solução escolhida
No, the batteries are different sizes and shapes, it's not going to happen
You can reduce your brightness, turn Wi-Fi and 3G if you have it off to save battery life, and turn them back on when using them, this will add a few hours to the run time
iPad 3 battery
iPad 2 battery
The connectors are clearly different as you can tell on the iPad 3 battery, and unless someone tries this on their 2, we'll never know.
Right now, no
Esta resposta foi útil?
Pontuação 1
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 1,468
