Ir para o conteúdo principal
The Meta Quest 2 (formerly Oculus Quest 2) was released in October 2020 and is the successor to the Oculus Quest.
164 Perguntas Visualizar todos
How do I adjust the quest 2 fan speeds?
I was just wondering how I can increase my fan speed. I always use it plugged in, so the battery isn't an issue. I want it to stop overheating, as it always does. Is there an app/way to do this?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
@bapergaming4 if it always overheats its not a fan speed issue but most likely a fan issue. Running it faster will not resolve the issue. I suggest that you replace the fan assembly and then re-evaluate
Meta Quest 2 Fan Assembly Replacement
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Bapergaming 4 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 25
