Ir para o conteúdo principal
Released September 24th, Apple's 2021 flagship smartphone features a 6.1" ProMotion OLED display, a new triple-lens rear camera system, and 5G. Successor to the iPhone 12 Pro.
64 Perguntas Visualizar todos
Is it okay to clean my phone’s charging port with nylon picks?
I’ve had an iPhone 13 Pro for a while and the time has come for me to remove some debris from the charging port. I was looking on Amazon for tools and I found a cheap, disposable set of nylon picks that are made for cleaning firearms but they look like they’d do the trick.
Is that material safe to use for this kind of thing?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
I would think your little nylon picks would be a good choice. The main things to avoid are metal, so you don't short the pins together while cleaning, and metal, something hard enough to damage the pins. So your nylon picks meet both criteria and will work great.
An eyeglass microfiber cloth and some 90% or higher concentration isopropyl (rubbing) alcohol, along with a nice bright light and magnifying glass would be the other things I'd want on hand. That should get you going; just take your time and be careful and you shouldn't have any problems.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
soupmode será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 5
Duração total: 40
