Ir para o conteúdo principal
Repair information for the 2007-2018 Jeep Wrangler, the 3rd generation or JK generation of the SUV. This line of off-road vehicle includes the Sport, Sahara, Rubicon and Unlimited editions.
jeep cranks won't start turn off and try again starts
jeep cranks won't start turn off and try again starts 2010
Esta é uma boa pergunta?
Pontuação -1
1 comentário:
What tests were performed? Is there spark? Are spark plugs wet and smell of raw gasoline after several failed starting attempts? Are all fuses checked? Is the factory or aftermarket antitheft system preventing starting/engine running? More details would help anyone see what you see.
por
Adicionar um comentário
1 resposta
In an engine it needs 3 things to run, air, fuel and spark so as it is cranking it has to be an issue relating to one of the 3 things so you should check if you have them 3 things and go from there
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Bob Conley será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Ao todo: 92
