Ir para o conteúdo principal
Repair guides and tutorials for E-Scooters.
My SWFT electric scooter doesn't turn on. I bought a new charger and i
My electric scooter will not turn on I put in you charger on it and still won't turn on
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
You can open it up and get to the battery. Using a voltmeter on the battery will tell you a lot about the problem. If the battery shows nominal voltage, then disconnect it and switch to ohmmeter to trace the wires for an open.
If the charger is good, plugging it in should allow it to turn on. Obviously, you can't ride it that way, but that would indicate an open circuit or a control component failure.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Edward anguiano será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 36
Ao todo: 421
