Ir para o conteúdo principal
Apple's top-of-the-line smartphone for 2020. Announced on October 13th and released November 13th, the iPhone 12 Pro Max sports a 6.7" OLED display, a triple rear camera system with LiDAR, and 5G connectivity. Successor to the iPhone 11 Pro Max.
105 Perguntas Visualizar todos
Which flex cable did I cut?!
I cut the flex cable that is exposed in the bottom left corner when I was replacing the back glass. And where can I find a parts diagram for this phone model?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Could you attach some photos of the damage?
por
Adicionar um comentário
2 respostas
Pergunta mais útil
Seems pretty obvious that you've cut the lightning port flex cable. If you look at the part being sold here on iFixit, the second (back side) picture shows exactly the area you're indicating.
iPhone 12 Pro Max Lightning Connector Assembly
Looks like iFixit hasn't quite gotten around to making a guide for that repair, but luckily there's a Spanish site called Nadie Me Llama Gallina that has just what you need to do that repair.
Manuales / Apple iPhone 12 Pro Max / Load Flex
Of course, since iFixit depends heavily on users helping to make guides, you can always add to the knowledge by taking lots of pictures during your repair and using them to create your own lightning port flex cable assembly replacement guide! It's fun, easy and will be greatly appreciated by everyone who comes after you.
Imagem de iPhone 12 Pro Max Lightning Connector Assembly
Produto
$79.99
Esta resposta foi útil?
Pontuação 1
I purchased this phone as is. Someone had previously tried replacing the back glass and front screen and quit. The one was functioning when I purchased it. Now I just need to figure out which flex cable it is. Thanks so much for any help.
Pontuação 0
Adicionar a sua resposta
i-need-heeelllllpppppp77 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 28
