problems with installing the top case
Hi I am trying to install a new top case on my macbook, so am busy removing the screws as per the directions given on this site. So in Step 6 the middle screw does not want to come out; and also the first screw in Step 9. Can someone please assist me with getting these screws out please? I am using the Phillips #00 screwdriver as instructed.
Many thanks
Verne
Esta é uma boa pergunta?
1 comentário
When the screws are removed for the first time from a computer you need to have the right tools (screwdrivers) and apply a little more pressure to remove them cause they are are stuck in the threads by a blue adhesive called loctite which is a threadlocker stuff. It prevents accidental loosening due to use and vibration.
por lemerise
