Ir para o conteúdo principal
Guias de reparo, manuais e ajuda para solução de problemas da placa-mãe ASUS. Obtenha tudo o que você precisa para reparar sua placa-mãe ASUS sozinho.
My computer electronics won't turn on when I power them on
When I connect my PC to the electronics line, the LED bulb on the motherboard lights up, but no fan turns on, the display does not come on, the mouse does not work, the keyboard does not work. When I connect my PC to the electronics line, the LED bulb on the motherboard lights up, but no fan turns on, the display does not come on, the mouse does not work, the keyboard does not work.
Esta é uma boa pergunta?
Pontuação 0
1 comentário
In general, when this happens, it means that there is a connection in the CPU phase circuit and the problem will be solved by removing the connection. Of course, make sure the CPU is healthy in advance. > With a multimeter, you will notice that all 4 pins are connected to each other, which should not be the case. Check the CPU phase input MOSFETs and replace the faulty part to solve the problem.
por
Adicionar um comentário
1 resposta
Solução escolhida
Sounds like a power issue. Had a similar thing once and it turned out to be a faulty PSU (Power Supply Unit). Might want to check yours or maybe try with a different one if you have a spare.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
ABR41 Riad será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Ao todo: 138
