Ir para o conteúdo principal
Apple's top-of-the-line smartphone for 2021. Released September 24th, the iPhone 13 Pro Max sports a 6.7" ProMotion OLED display, a new triple rear camera system, and 5G connectivity. Successor to the iPhone 12 Pro Max.
73 Perguntas Visualizar todos
Sim network not supported
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
u will need an unlock service
Esta resposta foi útil?
Pontuação 0
Here are some possible ways to fix the “SIM not supported” issue on your iPhone 13 Pro Max:
  • Check for carrier settings: Open Settings > General > About > Carrier Lock. If your iPhone is locked, contact your wireless carrier about unlocking your iPhone. If you don’t see this option, or if it says something else, try the following methods.
  • Eject and reinsert the SIM card: Look for the SIM card tray on the side of your iPhone. Use a SIM card ejector tool or a straightened out paperclip to open the tray. Push the tray back in to reseat the SIM card.
  • Force restart your iPhone: Press and quickly release the Volume Up button. Press and quickly release the Volume Down button. Then, press and hold the Side button until you see the Apple logo.
  • Reset network settings: Open Settings > General > Transfer Or Reset iPhone > Reset > Reset Network Settings. Enter your iPhone passcode, then tap Reset Network Settings to confirm your decision.
  • Update iOS with Reiboot: You can use Reiboot to update iOS on your iPhone 13 Pro Max. Download and install Reiboot on your computer. Connect your iPhone to your computer with a USB cable. Click on “Repair Operating System” and then “Fix Now”. Follow the instructions on the screen to download and install the latest version of iOS
Pontuação 0
Adicionar a sua resposta
Michael gezahegn será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 6
Duração total: 55
