Ir para o conteúdo principal
The Xiaomi Redmi Note 9S is a mid-range smartphone by Xiaomi released March 2020. It has a 6.67" IPS LCD display, a 48 MP main camera, a 5020 mAh battery, and runs on a Qualcomm SM7125 Snapdragon 720G.
Why is my phone's turbo charge doesn't function anymore?
battery drains fast and overheats.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Make sure your charger and cable are still good and provide turbo charge. Also if your battery drains fast you should replace it and a bad battery also could take less power at charging, so that's why it doesn't turbo charge. Also try to clean your charging cable and port with a toothbrush with some alcohol on it. Be careful put a small amount of alcohol on your toothbrush and not directly to the port and before plug your charger on, make sure it is dried.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Merly Caril será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 12
Ao todo: 266
