Why aren't I getting video in docked mode?
I'm trying to fix a Switch that doesn't get video while docked. When I plug it into the dock, I can see the charging symbol appear on the screen, and the dock's green LED turns on, so I know it's getting power. I can also tell that the system is properly on, because I'm able to navigate the menus while it's docked, I just don't get any audio or video while doing it.
I've tested it with another dock and power cable, so I know those aren't the issue. I opened up the console and started checking for shorts, but I haven't found any shorted capacitors yet.
Esta é uma boa pergunta?
3 comentários
Have you tried a different HDMI cable?
por Stranger
I believe I've found the issue. After testing numerous components on the board, it looks like the power management IC (M92T36) has a fault.
por Jane Cameron
@hiygamer42 Good job managing to isolate the problem. Assuming it's thee chip itself and nothing surrounding, it hopefully you'll manage to get your console working normally with a replacement or reflow.
por Stranger
