Ir para o conteúdo principal
Dell Inspiron 15 5558 is a Windows 10 Home laptop with a 15.60-inch display that has a resolution of 1366x768 pixels. It is powered by a Core i5 processor and it comes with 8GB of RAM. The Dell Inspiron 15 5558 packs 1TB of HDD storage. Graphics are powered by Intel Integrated HD Graphics 5500. Connectivity options include Wi-Fi 802.11 ac, Bluetooth, Ethernet and it comes with 3 USB ports (2 x USB 2.0, 1 x USB 3.0), HDMI Port, Mic In, RJ45 (LAN) ports.
Automatic repairing loop going on but I don't unable to open laptop
Automatic repairing loop continues and then restart
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi Rahul, Here are some possible fixes.
BIOS Settings
Power on and go into the BIOS Setup by pressing the F12 key then F10.
Go to General > Boot Sequence > Boot > Boot List Options
Change UEFI to Legacy or Legacy to UEFI and try to boot up to Windows. Usually it will be UEFI.
Windows Repair (Note: This can also be run from a bootable USB flash drive with the Windows installation on it)
Accessing Advanced Start-up when PC isn't loading:
If your device isn't loading or stuck during boot, you can use this method to access the recovery environment:
  1. Turn on your PC.
  2. As soon as the Windows logo appears on your screen, press the power button to turn off computer.
  3. Repeat steps 1 or 2 two more times.
After the third interruption, Windows 10 will open into the Advanced Start-up environment
While in the Advanced start-up environment, use the following steps to use Start-up Repair:
  1. Select Troubleshoot button.
  2. Select Advanced options button.
  3. Select the “Start-up Repair” button. That may be enough but if not follow 4. to 6.
  4. Select your account.
  5. Type your account password.
  6. Click the Continue button.
If the above doesn’t help do the same as above but this time select “System Restore” from the “Advanced Options?
Other possible fixes From CMD Prompt
 Run following:
  •  Chkdsk /F
  • SFC /scannow
  • Dism /Online /Cleanup-Image /RestoreHealth
Hardware
Run the Dell preboot diagnostic test (hardware) following these steps:
  1. Turn on your computer.
  2. At the Dell logo, press the F12 key several times until the One Time Boot Menu appears.
  3. On the boot menu screen, select the Diagnostics option and press Enter
More details on running diagnostics
Watch out for any error codes that the diagnostic displays. The link above explains the error messages near the bottom of the page.
Let us know how it goes for further help.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Rahul Verma será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 10
Ao todo: 83
