Ir para o conteúdo principal
The Suzuki Swift is a subcompact automobile manufactured by Suzuki, a Japanese automaker. The second-generation Suzuki Swift was introduced in September 2010 and replaced with a new generation in February 2017.
12 Perguntas Visualizar todos
How do you replace antenna?
My car swift 2010 model car antenna broken i bought new one i don't know how to fix it
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
@systemenginners you will need to remove the courtesy light. Once it is removed you should see the bolt that holds the antenna mount. Remove that to remove the antenna.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
System Enginners será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 11
Duração total: 130
