Ir para o conteúdo principal
CPU Replacement due to Failure
I took my iBook into an Apple store and the Apple team member inspected my iBook. He was very efficient and diagnosed my problem as a failing cpu.
He did not believe it was economical to replace.
Is it economical to replace my cpu? Should i just save the money and buy new MacBook Pro?
Btw - everything is already backedup.
thanks,
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
2 respostas
Solução escolhida
Assuming it's actually the logic board that is the problem, you can probably get a replacement board for $200, and it would then take you a few hours to replace it, if all goes well. If you are not up for an advanced technical challenge, such as this would be, you can buy a fully working equivalent machine on eBay in the range of $350. The choice, of course, would be up to you, and whether you want to take on a technical project, or just bite the bullet and acquire a working computer as soon as possible.
But as Matthew mentioned, let us know what symptoms you are seeing, and perhaps the problem is not as severe as they told you at the Apple store. For instance, does it make the chime sound when you power it on? Is there anything on the screen, and if so, what? What color is the light on the power plug?
Esta resposta foi útil?
Pontuação 2
The Processor is part of the logic board... Granted.. the Apple Store techs are not so bright... especially if they told you it was your CPU..
you may want to describe your issue here for more feedback - Most of us have actual experience repairing mac's..
figure logic board costing about 1/2 of a new MacBook..
Pontuação 0
Adicionar a sua resposta
Douglas será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 611
