Ir para o conteúdo principal
The Zoom H6 Handy Recorder is a portable audio recorder with interchangeable mics and several built-in effects, and can also be used as an audio interface for computers and tablets.
20 Perguntas Visualizar todos
What is the size of the SD card needed
What is the SD card size needed for a H6 Recorder
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @lmkstefans
The user manual doesn't specify the physical size of the SD card by name, only their capacity i.e. 16MB–2GB SD cards, 4GB–32GB SDHC cards, 64GB–128GB SDXC cards
The width of the SD card reader slot in the recorder may give an indication as to whether it is the standard, mini or micro size SD card i.e. 24mm, 20mm or 11mm
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
L.M.K Stefans será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 107
