Ir para o conteúdo principal
Repair guides and disassembly information for Apple's 7th generation iPad. Released September 25, 2019. Model numbers: A2197, A2200, and A2198.
doesn't turn on.
it was about a year ago when it stopped charging with its original charger, i then tried mac's charger to charge it. but it also didn't work, it was charging but very slowly and suddenly went dead since then.
i send it to local repair shop and they said probably it is motherboard issue and can't be solved. can you suggest me what to do?!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
I know it's a fairly common issue for the CPU to die on the 7 series and it's just not worth fixing.
You could reach out to a board repair specialist to see what they have to say. If you're out of the US, I believe iPad Rehab might be able to accept the repair. If you're in the US, both iPad Rehab and VCC Board Repairs could take a look at it. I've personally taken Rehab's board repair course and I send my data recovery jobs to Jesse at VCC. Good luck!
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Omor Seebtaien será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 10
Ao todo: 98
