My phone is lagging
When I start the phone the it start lagging
Esta é uma boa pergunta?
Hi @realmec11
Start the phone in safe mode and check performance.
If it is OK i.e. no lagging, then a downloaded app may be the cause of the problem. The trick is to find out which one is the culprit.
You will need to uninstall each downloaded app one by one and test the phone in normal mode between each uninstall. When it works OK in normal mode, the last downloaded app that you uninstalled was the cause of the problem.
A downloaded app is one that you downloaded and installed and wasn't pre-installed on the phone already.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 471
6 comentários
No sometimes lagging
por Najilnavas2
Yes i have this problem every day
por Shyam
Auto switch off mobile app not open
por Realms c12
por Ram Nishad
laggings realme c11 phone
por Realme c11
Exibir mais 1 comentário
