Ir para o conteúdo principal
The Dodge Avenger name returned in February 2007 as a 2008 model year sedan to replace the Dodge Stratus, whose coupe version had replaced the original Avenger in 2001.
13 Perguntas Visualizar todos
Camshaft and crankshaft sensor location
I can't find the camshaft sensor or the crankshaft position sensor on my 2010 dodge avenger 3.5l v6. Haven't been able to find videos on this specific one either.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi @chaserunyan
Here's a composite image from the 3.5L engine section of the 2008-2010 Dodge Avenger repair manual, showing the location of the sensors.
(click on image)
Update (08/22/23)
Hi @chaserunyan
Maybe check the wiring from the sensor back to the power train control module (PCM), especially the blue/grey wire
Here's the wiring diagram
(click on image)
Esta resposta foi útil?
Pontuação 1
1 comentário:
I switched out both sensors and my car is still popping codes for the camshaft sensor not really sure where to go from here. Like what to check next.
por
Adicionar a sua resposta
Chase runyan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 21
Últimos 30 dias: 91
Duração total: 453
