Ir para o conteúdo principal
In June 2017 Apple updated its 13" MacBook Air with a newer Broadwell Intel Core i5 processor, resulting in slightly increased performance and battery life.
417 Perguntas Visualizar todos
Why is the Keyboard not working?
My keyboard and trackpad stopped working. I need a replacement keyboard and trackpad after Apple diagnostics.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Did you take it apart?
Esta resposta foi útil?
Pontuação 0
Hold that thought! You don’t need a new keyboard or trackpad!
Your issue is more likely a bad trackpad cable. This series has a daisy chain setup where the keyboard connects to the trackpad and the trackpad cable carries the signals to the logic board.
Here’s the needed part MacBook Air 13" (Mid 2013-2017) Trackpad Cable
Review this guide Step 7 MacBook Air 13" Early 2017 Trackpad Replacement
Now let’s figure out why the cable failed install this gem of an App CoconutBattery post a snapshot here so we can see it. I’m suspecting the battery has swollen up pressing on the cable. Basically you might need a new battery.
Imagem de MacBook Air 13" (Mid 2013-2017) Trackpad Cable
Produto
$14.99
Pontuação 0
Adicionar a sua resposta
Charles Callahan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 18
