Ir para o conteúdo principal
Repair information for nebulizers, medical devices responsible for the administration of drugs to the lungs.
Whenever I connect the pipe to nebulizer the machine slow down.
When i connect the pipe to nebulizer the machine slow down after removing the pipe the machine run faster. Though i have cleaned and check the pipe nd even the nozzle but unale to sort the problem.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
@hrushikesh86167 that is to be expected. Once you connect the nebulizer the pressure needed to nebulize the medication is what is placing extra torque requirements on the machine. IT is not a matter of how much work your machine performs, the only thing that matters is how well it nebulizes the medication.
Of course, you always want to make sure that the container that holds the med as well as the nebulizer/mask as cleaned and replaced as per manufacturer.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Hrushikesh Sonawale será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Ao todo: 149
