phil, it is possible that this is caused by run down internal CMOS battery. the phone may have lost the boot settings and operating system. Just in case, you can follow the steps outlined here
" 1) Make sure you have Blackberry Desktop Manager installed.
http://na.blackberry.com/eng/services/de...
2) On your PC, go to Start > Run and copy and paste the following line exactly (meaning with the quotation marks):
"c:\program files\common files\research in motion\apploader\loader.exe" /nojvm
3) The Application Loader Wizard will appear -- click "Next."
4) In the "Connection:" drop-down menu, you should see "USB-PIN: UNKNOWN". Click the "Next" button.
5) You should then see a list of applications ready to be installed for your Blackberry. Hit Next and Finish. Don't disconnect anything and let the lengthy process finish completely." this info is from here.
If that does not resolve your issue, try to bridge the solder points on the filters. The diagram is available here. Those should of course be the last resort. Hope this helps to get you started. Good Luck.
6 comentários
my blackberry won't start,all I see is app error,what can I do???
por Ifa
my blackberry stop working all i see is whitescreen
por donovan henry
ween i open may blackberry hi put error what the problem and how to fix it
por emile
it wont let me install balckberry desktop manger what do i do ??? helpp meee please
por nikki wardell
my phone, i still get all the messages calls and everything and it has a short in it and i have tried many times to help you any help :(
por prehya
Exibir mais 1 comentário
