Ir para o conteúdo principal
The third generation Kia Rio debuted on March 1, 2011, at the Geneva Motor Show, again based on the Hyundai Accent.
8 Perguntas Visualizar todos
Pergunta encerrada
Ac isn't working well
My AC isn't working well
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
So the AC is working, is it just not as cold as you'd like it to be? If that's the case, I would start by putting a thermometer into the vents with the A/C on full blast and see what the temperature the A/C is blowing at and compare that to what the manufacturer says is the temp it should be blowing at. If you're in an area with extreme heat waves, there might be nothing technically wrong with your A/C. It just might not be able to keep up with the extreme heat, which is a common problem with lots of cars.
Esta resposta foi útil?
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 167
