Ir para o conteúdo principal
Brief one or two sentences with identification info. Example: Released June 2009, identified by model number A1303.
My acer nitro 5 dosen't turn
How can I fix it. Please help me
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
If your Acer Nitro 5 laptop is not turning on, it can be quite concerning. Here are some steps you can take to troubleshoot the issue:
  1. Check the Power: Make sure your laptop is properly connected to a power source and that the power adapter is functioning. Try using a different power outlet or a different power adapter if possible.
  2. Check the Battery: If your laptop has a removable battery, ensure that it's properly seated in its compartment. If it's a non-removable battery, skip this step.
  3. Perform a Hard Reset: Disconnect the power adapter and remove the laptop battery (if possible). Then, press and hold the power button for about 15-20 seconds. This will discharge any residual power from the laptop. Reconnect the battery and power adapter, then try turning it on.
  4. Check for Indicators: Look for any LED lights or indicators on your laptop. They might provide information about the power status or any potential issues.
  5. Try a Different Power Source: If you're using a power strip, surge protector, or extension cord, try plugging your laptop directly into a wall outlet to rule out any issues with the power source.
  6. External Display: If you have an external monitor, try connecting your laptop to it. Sometimes, the laptop screen might be the issue. If you get a display on the external monitor, it could indicate a problem with the laptop's screen or graphics.
  7. Disconnect External Devices: If you have any peripherals or external devices (USB drives, external hard drives, etc.) connected to your laptop, disconnect them and then try turning on the laptop. Sometimes, a faulty external device can prevent the laptop from booting.
  8. RAM Reseating: If you're comfortable opening up your laptop, try reseating the RAM modules. Sometimes, loose or improperly seated RAM can cause booting issues.
  9. Contact Acer Support: If none of the above steps work, it's recommended to contact Acer's customer support or visit an authorized service center. The issue might require professional diagnosis and repair.
  10. Warranty Consideration: If your laptop is still under warranty, reach out to Acer's support as soon as possible. Opening up the laptop or attempting repairs yourself might void the warranty.
Keep in mind that laptops are complex devices, and some troubleshooting steps might require technical expertise. If you're not comfortable performing certain actions, it's better to seek professional help to avoid further damage.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Sergej será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 3
Ao todo: 269
