Ir para o conteúdo principal
Eighth generation of iPad, released September 18, 2020, available in 32 or 128 GB models. Model Number A2270.
15 Perguntas Visualizar todos
I cracked my screen, and now half of it is black but still responsive
so, my screen was cracked and I found it to have part of the screen being black but still responsive. What can i do to fix this?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
@susdy So if the screen is still responsive to touch, the touch layer, also known as a digitizer, is fine but the LCD (the part which shows pictures) has cracked. The good news is that for the iPad 8, the LCD and digitizer are separate. You can replace the LCD while leaving the digitizer layer alone, which will save you some money. You can refer to the iFixit guide here if you are able to repair it yourself, if not, repairing it at a shop will cost you around $100-150 USD. Remember to emphasize that the touch layer is working fine and insist on an LCD-replacement only if you go this route.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Susdy será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 14
Duração total: 180
